Roofbar fitting problems
Have just purchased a set of genuine renault megane roofbars from Ebay. Tried fitting them the other day. Opened little latch on roof. There is a bolt into the roof. In the middle of the bolt is a hole which a smaller bolt on the roofbar screws into. Slight problem - there is a plastic screw already in the hole. When I tried undoing it with a screw driver, the head went round and round then fell off leaving the rest of the plastic screw in the bolt hole. The exact same thing happened to the next screw. I then gave up. What am I doing wrong? How are you supposed to get the plastic screw out? How do I now get the rest of the plastic screw from the middle of the bolt hole? Anyone had a similar problem?
Renault Megane 53/2003 1.6 VV Dynamique
I drilled the plastic screws out of the bolt holes but the bolts from the roof bars would not screw into it, I think I ruined the threads with the drill. In the end I bought some more bolts from Renault Dealership @ £1.86 each. The plastic caps came off no problem and the roof bar bolts threaded into them very nicely. The Roofbars are now on my Megane. Thanks!!
