Changing glow plugs 3 and 4
willtheflip
Postby willtheflip » Fri Sep 21, 2007 9:14 am
Just had a service from Renault dealer and they put the check injection light down to faulty glow plugs on 3 and 4 cylinders. There charge was £95 but I would like to change them myself. Does anyone have an instuction on how to do this?
IainMW
Postby IainMW » Fri Sep 21, 2007 9:22 am
They are quite easy to change, very similar to changing a spark plug.
See if you can get a copy of the Haynes manual for the Megane as this will detail it correctly.
All you need is a socket set and the new glow plugs
You just have to be carful not to snap them off in the head when removing them. Or you will have a big bill
:cry:
£95 is very steep, a decent independant will do it for a lot less if you don't fancy it yourself.
