Page 1 of 2
Which Iridium to choose?
Posted: Sat Apr 28, 2007 10:33 am
by meganeboy
Hi guys, a quick one here..... which is the best iridium plug to fit, NGK or Denso?
I found them on eBay as they are not available locally. NGK plugs are aroung GBP25 set of four, while Denso are GBP35. NGK are 0.6mm while Denso are 0.4mm..... got confused now!!
Help please
Posted: Sat Apr 28, 2007 2:02 pm
by WebCode
Make sure they are "resistive" plugs you are fitting as non-resistive ones can cause running problems due to interference/radiation from the ignition system..
Posted: Sat Apr 28, 2007 2:19 pm
by meganeboy
Hi Webcode, the Denso plugs have a 5kohm resistance in built... don't know about the NGK though.....
Posted: Sat Apr 28, 2007 2:29 pm
by MrAsia
I have NGK ones.
Very good, responsiveness changed.
Also when I let go of the clutch the car doesn't tremble as much. If you get what I mean. This is when no accelerator is applied and car is stationary, the friction point.
Posted: Sat Apr 28, 2007 6:20 pm
by rFai
In my personal experience i can say that i have got NGK and they had been broken after 1 month driving, than i buy BERU and they are still staying in my car :P
Posted: Sat Apr 28, 2007 8:53 pm
by xirc0m
The exact part no . BKR6EIX
Been using it and sold a couple of it to fellow M2 owners in Singapore... its a 0.9mm gap... more responsive...
Posted: Sat Apr 28, 2007 9:30 pm
by meganeboy
Has anyone out there tried the Denso plugs? is it an advantage to have the tip smaller than the NGK plugs?
The NGK's tip is 0.6mm, Denso's is 0.4mm. Any ideas?
Posted: Sun Apr 29, 2007 8:25 pm
by xirc0m
meganeboy wrote:Has anyone out there tried the Denso plugs? is it an advantage to have the tip smaller than the NGK plugs?
There is no direct part no for Denso to be use for Renault M2... which means u got to Re-Gap it... and I would not recommend it...
I do have some guys I know who use it and complain...
NGK for far no problem
Posted: Mon Apr 30, 2007 5:01 pm
by meganeboy
xirc0m wrote:The exact part no . BKR6EIX
Part no. quoted by the supplier (and site) is BKR6EZ for the NGK IX plugs.... can anyone confirm this pls?
Posted: Tue May 01, 2007 9:03 pm
by xirc0m
meganeboy wrote:xirc0m wrote:The exact part no . BKR6EIX
https://www.ngk.de/index.php?id=659&pd=6 ... M%E9gane+2
https://www.ngk.de/index.php?id=660&test ... erzen/8897
https://www.spark-plugs.co.uk/cars/renault.htm
Posted: Thu May 03, 2007 12:40 pm
by meganeboy
Hey guys.....
Just changed the standard plugs to NGK Iridium and I can say they do quite a difference on the car's performance.... it feels much better, idling is smoother, and accelleration feels better too.....
While messing around with the car, I also took the bumper off and replaced the standard bulbs to Osram SilverStar. I noticed that I had one of the headlamps loose from the bottom and after re-installing everything went for a test drive and I can say that the small banging sound I used to hear from the front went away. Turned out to be this loose headlamp!
Quite happy now. Any idea if aftermarket ignition coils would further improve the performance? was having a look at these :
https://www.beru.com/english/produkte/pr ... ur+(KM0/1_)&typ=1.6&ktypnr=17731&action=step04
Tks to all
Posted: Thu May 03, 2007 7:22 pm
by xirc0m
meganeboy wrote:Hey guys.....
Tks to all
Cool ! Beru Ignition Coil...
- How much issit selling @?
- Whats the diff. compare to Stock Ignition Coil?
Posted: Fri May 04, 2007 12:28 pm
by meganeboy
xirc0m wrote:meganeboy wrote:Hey guys.....
Tks to all
Just got a quote from
https://www.sparkplugs.co.uk for the Beru Ignition coils. They sell at £20.02 + VAT each + shipping.... not that bad at all!!
Posted: Sat Nov 03, 2007 7:07 pm
by Ozzy82
hi all. i was just wondering if someone could post me a link to a website which sells ngk iridium plugs please??
Posted: Sat Nov 03, 2007 7:33 pm
by meganeboy
got mine from ebay......
