8mm square socket
Posted: Sat Feb 24, 2007 4:05 pm
by dewitt21
hi i want to change my oil but i cant find the 8mm socket anywhere? any ideas? thanks
Posted: Sat Feb 24, 2007 4:59 pm
by Mat
Think you have to take the plastic cover off the bottom
Posted: Sat Feb 24, 2007 9:15 pm
by dewitt21
sorry, i mean im looking to buy a 8mm square socket tried ebay but not there?
Posted: Sat Feb 24, 2007 10:22 pm
by DJC013
Hello, i use a Draper 8mm square drain plug key. It fits onto a 3/8" ratchet. The Stock No is 38324, the Part no is DDPK6, if you go onto there website you can use the Find a Stockist function for your local dealer. hope this helps, regards Damian.
Posted: Sun Feb 25, 2007 10:00 pm
by AlexB
Posted: Tue Feb 27, 2007 1:47 pm
by DaveP
Being a tight fisted git I found an old bolt in the bottom of the toolbox and ground the threaded part square with an angle grinder till it was a perfect fit in the hole. I then put a normal socket on the bolt head and Bob's your auntie's lover.
Posted: Fri Apr 13, 2007 1:10 pm
by chris garland
The square bar that connects domestic door handles is 8mm...
Chris
