renault megane 120 clutch bleed control
- Currently Drives:: Renault Megane gt 150 gt 2007
The bleed control fits on to clutch slave cyl and connects to clutch pipe The bleed control is plastic it as 3 spring clips 1 to loch onto flud pipe the other end as got 2 clips that fits to clutch control id You put plastic pipe on control bleed valve move it till fluid flows out then push in and the clutch should work I have tried main agents scrap yards everyone i know Hope some one can help
- Stranger
- Currently Drives:: BMW X1
Re: renault megane 120 clutch bleed control
Try posting in the wanted section too, you never know your luck
Users browsing this forum: Bing [Bot] and 4 guests
