Hi.
Anyone know if the brake calipers are the same across the megane range? I have the 2.0dci, and got the impression that the caliper was the same for the 1.6, 1.9 and 2.0 engines. Can anyone confirm or point me in the right direction so I can find out myself?
Thanks!
Ian
brake calipers
- MilosB
- Currently Drives:: R. Megane 2 1.9dci sport package
Re: brake calipers
they should be the same, you should only take a cloase look if you are replacing them to replace with the same manufacturer. there are 3 manufacturers fitted and all are with 54mm dia piston
Re: brake calipers
I was also confused on the matter as I have also the same vehilcle. Your information provided great help to me also. Thanks
Users browsing this forum: No registered users and 16 guests
