2003 - Megane 1.5DCI Chip-Box
GAZ6693
Currently Drives:: Renault Megane 1.5DCI Dynamique
Postby GAZ6693 » Fri May 11, 2012 6:36 pm
Can anyone suggest a descent Megane 1.5DCI plug & play Chip-box to improve performance/economy?
I have seen a few on ebay - anybody got any feedback on them?
Re: 2003 - Megane 1.5DCI Chip-Box
Postby joeishmather » Fri May 11, 2012 7:09 pm
I had one which was good, from an Italian company, belive it was called a drake box two, or something along those lines.
Postby davelowe » Fri May 11, 2012 10:15 pm
The merits, or lack of, these units have been discussed ad infinitum. Personally I would go for a re-map, as I regard these units to be worse than useless. However, others disagree. Let the debate continue...
GAZ6693
Postby GAZ6693 » Sun May 13, 2012 10:21 am
Postby davelowe » Sun May 13, 2012 10:27 pm
I would still advise against. My reason is that these boxes are a simplistic way of tricking the ECU into providing extra fuel (amongst other things). A re-map done properly will do the job much better and more reliably.
The choice is yours. I have no empirical evidence either way.
smart_d
Postby smart_d » Sun May 13, 2012 10:54 pm
Hi Gaz,
I have just bought one of these https://www.ebay.co.uk/itm/Renault-Megan ... 4cfbe48302. Absolutely fantastic piece of kit for the money and from a good company. Was contemplating over this and an ECU tune, but glad I went with this and on a plus side you can also tune the box to give to more power. MPG has also increased.
Meganedci06
Currently Drives:: 2006 megane dci
Postby Meganedci06 » Sun Jul 22, 2012 12:21 pm
did u find a better responce to the turbo. i find my 1.5dci has a hell of a lag on it and wondered if these would help this. not to fussed on mpg (would be an advantage) as i dont travel alot a miles to work and back.
rjk1188
Currently Drives:: 1.9 dci laguna
Postby rjk1188 » Sun Aug 05, 2012 12:24 pm
i have a pro-bitz on my 1.9 dci which is a good box
