Megane 1.9 dci cam belt kit
Posted: Wed Aug 25, 2010 8:41 pm
by Moggy19
Hello all, I have a 2006 Renault Megane 1.9 dci (130) due a cam belt and roller set change soon. Any ideas where I can get a set at a reasonable price. From what I understand you have to change the rollers as well as the actual belt itself.
Many Thanks
Re: Megane 1.9 dci cam belt kit
Posted: Wed Aug 25, 2010 10:12 pm
by davelowe
The 1.9dci 120 original Gates belt kit and water pump can be had from ebay for around £100 - £120. Not so sure about your engine. Obviously labour will need to be added as I believe that the tension is measured by an instrument that gives a frequency reading.
On the 120bhp it is normal practice to change the water pump (£30) as part of the service as it can only be accessed with the cam belt off. Whilst you're at it - also renew the coolant.
Posted: Sun Aug 29, 2010 9:09 pm
by BlueMeganeII
I've been looking through ebay. Do those Gates kits have all belts and the waterpump in them? I've been quoted £200 by a local garage for the kit alone plus £240 labour, so getting the kit would be a big saving itself.
