I have just bought air and oil filters from Halfords
Surely they should be okay
AlexB wrote:People tried cut open the filters for comparison. The OEM filters are made by Purflux and have the largest area of the filtration material inside. This is due to a patented war of "pleating". They are also more robust to collapsing under pressure than some cheap brands, including those that are re-branded as Halfords.
I would not be taking a risk for the sake of saving £2. Then, it is a false economy, as you will have to replace it half way, i.e. 4.5k miles.
My choice is the OEM filter and Mobil 1 0w40. Never had problems with the engine.
LeeUK wrote:AlexB wrote:People tried cut open the filters for comparison. The OEM filters are made by Purflux and have the largest area of the filtration material inside. This is due to a patented war of "pleating". They are also more robust to collapsing under pressure than some cheap brands, including those that are re-branded as Halfords.
Hmm, you say cheap brands but Purflux are one of the cheapest in France, sold in most supermarkets!
Not bothered too much with the oil, regular changes with normal oil has served me fine with Scoobies and Mitsu's in the past
Cheers for replies
davelowe wrote:LeeUK wrote:AlexB wrote:People tried cut open the filters for comparison. The OEM filters are made by Purflux and have the largest area of the filtration material inside. This is due to a patented war of "pleating". They are also more robust to collapsing under pressure than some cheap brands, including those that are re-branded as Halfords.
Cheers for replies
Jesus, you are seriously asking for trouble!
The dci engine likes a special brew and very regular changes of oil. It's not by chance that Renault halved the service intervals and then re-specified the oil requirements - they did it for a reason - not least because many turbos went south...
