Front Brake Disc Change
druboy
Postby druboy » Fri Jul 16, 2010 5:20 pm
Any one changed front discs on a 1.9dCi?? Is it an easy job? How to's??
Any special tools required??
Cheers :-)
rjacko
Currently Drives:: Renault Megane 1.9 dci Dynamique, 3dr 03 reg
Re: Front Brake Disc Change
Postby rjacko » Fri Jul 16, 2010 6:19 pm
yeah did the discs and pads on mine last friday. No specialist tools required, just make sure that you got copper grease to put on the back of the pads to stop brake squeal and thread lock for the bolts for the calipers.
Do a search for how to's on here should be a sticky. If not if your close can lend a hand.
Postby AlexB » Mon Jul 19, 2010 11:59 pm
It's in the manual in the "sticky" thread above the other threads. The job is very simple. The only thing... if the replacement discs are not OEM, then they will need balancing. At least EBC and Mintex discs do.
Postby Anthony » Tue Jul 20, 2010 9:03 am
Buy Brembo for ready balanced discs.
