Does anyone know if you can buy the small rubber pads that the electric windows sits on as a replacement part? My left window is rattling like a diamondback because its lost one of the bits of rubber.
Can you buy these small black rubber mats that the windows sits on as a replacement part? Or do you have to replace the whole mechanism?
Rubber pad that window sits on?
Re: Rubber pad that window sits on?
I had a similar problem. Well i wrecked the pad when changing the regulator.
I would find a replacement so imprevised with some sticky back foam strip. Although i added some industrial glue to the sticky part.
Does the job rightly.
