can anybody tell me if it exists some aftermarket stop lamps for the magane 2 saloon? because I search in central europe and didn't find anything.
P.S. sorry for my english
Hello!!!
- Steel
- Currently Drives:: Renault Mégane III 1.5 DCI110
Re: Hello!!!
Hi there, i have never seen any aftermarket rear/taillamps for the Saloon.
I have changed to the phase2 type on my 2004 Saloon an this is how it looks:
Re: Hello!!!
Is that a volvo c40 spolier? from 2000 or sometime round then?
- Steel
Re: Hello!!!
ulrich100 wrote:Is that a volvo c40 spolier? from 2000 or sometime round then?
It´s the original spoiler for S40 ym 1996-2004
Re: Hello!!!
Nice just picked one up off ebay for £23 could you explain how you went about fitting it?
Regards
Regards
- Steel
Re: Hello!!!
ulrich100 wrote:Nice just picked one up off ebay for £23 could you explain how you went about fitting it?
Regards
The outer screws was removed and the holes were filled with plasticpadding so that the surface that sticks out was smooth.
I used the original adhensive tape for the S40, Volvo part.no: 2pcs 30851036.
There will be a bit of a gap between the hood and the spoiler on the inside, but i didn´t care about that.
Goodluck
Post som pictures when youre done
Re: Hello!!!
Will do, so no bolts required?
And your sure it wont blow off if i just use tape?
- Steel
Re: Hello!!!
ulrich100 wrote:Will do, so no bolts required?
Cut off the outer screws on each side use the inner ones for mounting !!!
