Front coil spring
bogsdollox
Front coil spring
Postby bogsdollox » Wed Jul 07, 2010 8:04 pm
Hi, could somebody tell me if there is already a link somewhere on here for replacing the front coil spring. If not would someone please explain how to replace one please as mine has snapped.
Many thanks
Re: Front coil spring
Postby davelowe » Wed Jul 07, 2010 10:08 pm
Yes there is a thread. You will need to separate the bottom bit, and unbolt the top bit. Then you need a spring compressor to avoid killing yourself.
If you don't understand the need for the spring compressor - trust the job to a garage. Oh and it's a funking ball ache of a job (bad access and radiator under-frame has to come out if I remember correctly).
Lots of threads on here - search!
bogsdollox
Postby bogsdollox » Thu Sep 02, 2010 8:46 pm
Thanks for the valuable info dave. Do not know what car you were changing a spring on though RE: ........... and it's a funking ball ache of a job (bad access and radiator under-frame has to come out if I remember correctly). :?:
Had a pair of spring compressers made in work, whole job less than 1 hour to do.
Users browsing this forum: No registered users and 16 guests
