brake calipers
ibiker
brake calipers
Postby ibiker » Mon Apr 13, 2015 6:28 pm
Hi.
Anyone know if the brake calipers are the same across the megane range? I have the 2.0dci, and got the impression that the caliper was the same for the 1.6, 1.9 and 2.0 engines. Can anyone confirm or point me in the right direction so I can find out myself?
Thanks!
Ian
MilosB
Re: brake calipers
Postby MilosB » Thu Jun 25, 2015 6:56 pm
they should be the same, you should only take a cloase look if you are replacing them to replace with the same manufacturer. there are 3 manufacturers fitted and all are with 54mm dia piston
ibiker
Re: brake calipers
Postby ibiker » Thu Jun 25, 2015 10:44 pm
Thanks!
IanB
davidjones
Re: brake calipers
Postby davidjones » Thu Aug 27, 2015 10:22 am
I was also confused on the matter as I have also the same vehilcle. Your information provided great help to me also. Thanks
