Hi all,
The wife has just changed her car for a megane cc, 05 plate. I have to say its very nice to drive. Just one question though, if the main car battery fails with the vehicle locked, how do you get in, as everything is electrical?.
Thanks,
Mark
How do you get in if the battery fails?
- Currently Drives:: Mégane II Ph.1 1.6 16v Dynamique Luxe, full leather seats, Carminat Informé 1 with CD-changer.
Re: How do you get in if the battery fails?
What about using the emergencykey in your keycard? Might be an option...
- Currently Drives:: megane cc and a astra van sportive SE
Hi again,
Didn't know there was one?. I will have a look when the wife comes back in,
Thanks,
Mark
Thanks,
Mark
It has a cover on the lock located on the door handle, to get the cover off just use the key and push it into the hole at the bottom applying a little pressure towards yourself and it should pop off reveiling the lock, watch it thought as when I had to gt into mine the cover shot off and nearly went down a drain!! The key will also fit into a lock next to the OS number plate light allowing you into the boot should the battery die.
megane cc 106dci 57reg quartz
Thanks all
- busternlouie
Or if all else fails....
Users browsing this forum: No registered users and 22 guests
