Cc trunk is touching plastic when opened
rdp1612
Currently Drives:: Renault megane ii cc 2004
Postby rdp1612 » Sun Jan 06, 2019 11:21 pm
Hi all,
Hope I explain this clear enough, this only happens when the top is off.
When opening the trunk it keeps hanging on the plastic part (don’t know the partname, sorry) at the end of it. I cam force it to open by using more strength but this damages the paintjob!
When I press/ hold the plastic part I can open the trunk without problems.
Anybody here who knows this issue and has an solution for it?
Cardetails: megane ii cc 1.6 2004
Thanks in advance!
Malroy
Currently Drives:: Megane II CC
Re: Cc trunk is touching plastic when opened
Postby Malroy » Tue Apr 09, 2019 8:10 am
Sorry but hard to understand your issue from info provided. Not experienced any like issues with my 2004 cc but an image would help. Also, is the issue roof up, down or both? When closed are the shut lines even and does it open and close with the latch easily i.e. You don't need to tug it to open or slam it to close?
