Camshaft sensor
Posted: Fri May 19, 2017 3:17 am
by Mtb
Hi everyone , I have a 05 megane cabriolet and I need to change the camshaft sensor...... Any one know where it is as I can't find it
Thanks in advance !
Re: Camshaft sensor
Posted: Fri May 19, 2017 3:40 pm
by BrotherPlasterer
Top right of engine looking from front.
Just to the side of the sparkplug on cylinder no 1 (French) furthest from auxiliary belt.
I think its a 10mm bolt and you are able to get it out with some manipulation of spanner.
Remove the coil first to make access easier.
Out of curiosity why do you need to change it?
Re: Camshaft sensor
Posted: Fri May 19, 2017 6:15 pm
by Mtb
Hi thank you for the reply , I am replacing the sensor as it came up on a fault code , so I thought first as last buy a new one and have done with
Re: Camshaft sensor
Posted: Sat May 20, 2017 2:19 pm
by BrotherPlasterer
Fair enough, what was the code?
Any symptoms?
Re: Camshaft sensor
Posted: Sat May 20, 2017 2:40 pm
by Mtb
Hi there 2 fault codes came up ,
P2002 & p0340
The soot filter is driving me nuts , the " regenerate the soot filter " is on and off more than I drive the car lol.
P0340 came up for the Camshaft sensor , so I purchased a new one
Melanie
Re: Camshaft sensor
Posted: Sat May 20, 2017 3:23 pm
by BrotherPlasterer
Ah a diesel.
Do you motorway much?
Maybe it needs a good burn out at constant high speed for a while.
With regard to the cam sensor, if you got one already then change it but don't throw the old one because its probably only dirty.
Let us know.
Re: Camshaft sensor
Posted: Sat May 20, 2017 4:55 pm
by Mtb
Thank you ever so much for the advice , I don't do a lot of motorway driving , so I am thinking or having the engine and system Terra cleaned to see if that will help
