help needed please
Posted: Mon Sep 12, 2016 4:55 pm
by slim129
Re: help needed please
Posted: Mon Sep 12, 2016 6:54 pm
by ChrisM
Get it plugged in and code read see if it gives itself away.
I am always suspicious when I buy a used part and car still presents exact faults again what are those chances?
So is it the part or the car, you might find its needs the ecu cleared out of redundant faults before you fork out £200 for a new one.
How didyou charge it on the car or off, did you disconnect it or leave terminals on battery guessing at 24hrs it was a trickle charge.
Posted: Tue Sep 13, 2016 4:39 pm
by slim129
thanks for the reply mate tried that yesterday kept coming up no codes, took battery out done in house this must have happened to someone else just need a yes or no on the stalk.
Posted: Mon Sep 19, 2016 8:35 am
by q292u
Firstly, I'm not a Megane specialist, but I have a lot of years tinkering with cars behind me..
If you've had two stalks in the car, and both give the error, it's probably not the stalk. (Unless there is a common fault with stalks failing..)
The car was without power for a long time - it's more likely something electronic has failed during that time. There are a lot of possible culprits on a Renault..
How to find the fault? I'd plug in my cheap code reader (one of the bluetooth ones that connects to Android devices.).
If there really are no codes, then I'd take it to a local auto-electrics place that does free diagnostics. (T.H. Flory in Middlesbrough in my case)
Renaults (and especially Megane IIs) are notorious for electrical faults. Mine currently has two, but I know if I fix one, another two will pop up..
Posted: Mon Sep 19, 2016 4:40 pm
by slim129
thanks for post mate, i did take it to a auto-electrics for a diagnostics test and there the ones that said it was the stalk. thanks again
