Hi All,
New to the CC, had it a couple of weeks and both the rear windows suddenly stopped working. Unfortunately I have no manual, so don't know if just fuse, or where this is.
No Button makes them work..
Loving the car though, bargain economical diesel for less than a week away.
Regards
Meljak
Neither Read window suddenly works on my 2005 CC
- Currently Drives:: 2005 renault megane CC 1.6 16V
Re: Neither Read window suddenly works on my 2005 CC
Hello mate.
When my both rear windows wasn't working I had my mate to check them( he is an auto electrician) he plugged he's favourite meter and figured out that ther is not enough power going to rear regulators. Was only about 6 volts. So he said that there is some problem with power wire from fuse box. So I ran extra cable from fuse which showed 12v on it. Ran cable to only one side as both having same power supply. And rears working again. Check fuse box. You can get manual somwhere here. When I have some more time i will strip the carpet and have a look how wires looking underneath it. Aparently there is connector behind front seats and wiring harnes to the rear.
Fuse box is in the glove box and all the fuses are marked on it....that might be just one of the many problems. But if its both the same time I would blame wiring not the regulators...
Hope this long and boring answer helps
