SOME HELP PLEASE
shepo08
Currently Drives:: megane II Convertible
SOME HELP PLEASE
Postby shepo08 » Thu Jun 18, 2015 6:32 pm
HI GUYS HOPEFULLY YOU CAN HELP ME OUT PLEASE ON A FEW THINGS , MY MEGANE 54REG CC HAS DECIDED ITS WANTED TO JUST START BREAKING ON ME , HOPEFULLY HAVE SOME TIPS PLEASE TO FIXS THESE PROBLEMS.
FIRST. MY FRONT 2 WINDOWS SEEM TO BE VERY SQUEAKY AND THE DRIVERS SIDE ONE IS REALLY BAD AND ALSO I HAVE TO KEEP PRESSING IT TO PUT THE WINDOW UP OR DOWN IT MOVES LIKE 3CM A TIME , ANY HELP ON THIS ONE PLEASE????
2ND. WHEN I PRESS MY BRAKE PEDAL IN SOME REASON MY SIDE LIGHTS COME ON ?? ANYBODY KNOW WHY?
3RD. CAN SOME ONE PLEASE TELL ME WHERE I CAN FIND THE BRAKE LIGHT SWITCH , AS I NEED TO CHANGE IT DUE TO MY REAR BRAKE LIGHTS JUST STAYING ON.
FINALLY. MY FRONT DRIVERS SIDE HEAD LIGHT DOSNT SEEM TO BE WORKING AND I HAVE PUT A NEW BULB IN AND STILL DOSNT WORK??
HOPEFULLY YOU GUYS COULD GIVE ME SOME ANSWER BE REALLY HELPFULL
THANKS, SHEPO08
Andy1985
Re: SOME HELP PLEASE
Postby Andy1985 » Fri Jun 19, 2015 6:03 am
Hi
First question is has your battery recently gone black or have you had problems trying to start it if so the windows go into a mode where they only work like inch at a time.
The best way to get rid of this push the button all the way up or down and hold it there and then keep.putting window up and down this should stop it.
The brake switch is usually at the back of your brake pedal or under the glove box you will need to move Ur bit of carpet what's there
Regarding you headlight I couldn't say as I'm having the same problem one side works other doesn't I've checked fuse and also bulb but nothing it's only the passenger side what's what's fault if you get your headlight let leletletley me know as I'm at a loss
shepo08
Postby shepo08 » Fri Jun 19, 2015 1:35 pm
thank you very much i will try that with the windows see if i get any look any i will also look at my battery check that too and thanks i will try find that switch today and for the lights yes i am really confused people infront must think am mad when i brake thinking whys he keep putting his side lights on haha .
