Engine fusebox
Posted: Mon Sep 08, 2014 7:40 pm
by FEWRIOUS
Hi all just wondering if anyone has a listing of the fuses under the the bonnet as I've lost the use of the windscreen washers and also the horn has stopped working and is there a set of fuse actually inside the main box as well ??
Re: Engine fusebox
Posted: Sun Oct 26, 2014 10:10 am
by tonystime
If you take the top of the fuse box off it has a list of the fuses underneath.
Re: Engine fusebox
Posted: Tue Oct 28, 2014 2:19 pm
by AlexB
The list is in the thread with manuals in Problems forum. Look into MR364MEGANE8.pdf
Re: Engine fusebox
Posted: Wed Dec 03, 2014 3:37 pm
by Whitelaw87
This isn't the fuse box under the bonnet, the fuses for these problems are in the glove box to the left hand side, just pop the cover off and you will see the fuses, the cover should also have a sticker on it showing which fuse is which
