Hi
New cc owner here.
Can't seem to get the cruise control to operate, press the switch but no light comes on the dashboard, is this fused or could there be a wire off, the speed limiter does not work either.
Any advice would be greatly appreciated
Many thanks
Glynn.
57 plate cruise control
Re: 57 plate cruise control
You need to have someone connect a clip to it to let it know it has cruise control if you want it to show on the dash, it will work however without it being programmed in
- Currently Drives:: Megane convertible mkii 57 plate
Megane grand scenic mkii 55 plate (wife's)
Thanks for the info, I will get it booked in.
Glynn.
Glynn.
Just to add any decent auto electrician should be able to do it, dont get stung by renault..
Thanks for the heads up, had the car back to the dealer who sold it and they were no use the most they could tell me was that there is power going to the system but that was it. Just to clarify I am getting no green / orange light on the dash when the switch it on is this what you mean when you say an auto electrician needs to tell the car it has the system so it will actaully turn on ?
Looking for a local auto spark tomorrow so could do with going in with some info.
thanks in advance.
apart from this minor issue I am 3 weeks into cc ownership and am loving the car.
Glynn.
thanks in advance.
Glynn.
- Rally Driver
have you read the manual on how to operate the cruise control as there is also a switch to operate on the right hand side of the dash where you level the lights for different loads
Hi
yes its this switch which is not illuminating the indication on the dashboard on the speedo dial when pressed for either SL or CC option.
Glynn
Glynn
Hi
I know this thread is a few months old, but I just wondering if you sorted out your cruise control. I've got the exact same issue with my Renault sport megane R26.
