Side body moulding fitted
Posted: Sun Apr 08, 2012 10:01 am
A common trait with the cc is car park dings on the ridge of the doors and rear wings, I looked at 5 or 6 cars before buying one and all of them had this to some degree. The one I bought was by far the best but it still annoyed me whenever I polished the car that from certain angles you could see slight dings, dents and the odd touched in paint chips along the ridges, those with dark colored cars will notice this much more. Now the bodywork on my car is better than most and most of the time you couldn't see them as they are minor but it probably represented 75% of all body imperfections on the car. I'm one of those people that when using a car park think carefully about where to park and take into account things like is the car next to me a 2 door, does it have a child seat in the back, is it beaten up and uncared for etc etc, some of you will know exactly what I mean and yes I know I'm sad. The reason that the CC picks up these dings is because there is no flex on the ridge as there is on the flat parts of the panels so a minor impact causes damage also the ridge seems to be the widest part of the car if you don't take into account the wheel arches. I thought long and hard on how to remove or hide the dings and also prevent further damage and found a side body moulding on a roll on a well known website. The moulding is 18mm x 4mm, has a chrome insert and cost £24 delivered. I wasn't sure what it would look like or how it would sit on the ridge, I stuck with 18mm as it would easily cover any damage and being narrow would stand the best chance of fitting on the uneven surface, it's also in keeping with the window rubbers above.
Having now fitted them I'm actually rather pleased with the look of them, they fitted over the ridge better than I could have hoped for and have broken up that massive door panel nicely. I personally think it's also added to the overall styling, obviously it's a personal thing and I'm sure others may disagree but there's no denying it has successfully hidden the damage for which I am really very pleased.
