Various errors
ziik
Currently Drives:: BMW X5 3LTR D
MEGANE CC 2007
Various errors
Postby ziik » Sun Feb 05, 2012 2:25 am
Was with friend and got stuck in traffic . With it been snowy she was driving calmly next minute error comes up check gearbox. Then abs light then stop check braking system. She freaked out and said Neva has she had problems but since the track rod end pullava all this.
Can anyone explain these errors. I said gearbox could be cos of weather but last year it was much worse and she was driving and never had this problem.
Advice appreciated thank you
lee00069
Currently Drives:: 2005 megane cc 1.9 DCI
Re: Various errors
Postby lee00069 » Mon Feb 06, 2012 6:23 pm
could possibly be the fuse box,
on top the front left wheel there is a cover on the fender lining . it has a small easy to remove round piece of plastic that is used when changing the left headlight globes.
If that is missing some water or salt water could have gotten into contact with the fuse box (which is just behind the cover) and caused damage to it.
check if that cover is there and if not i think you will need a new one.
