roof mechanism fault
- Currently Drives:: megane cc 20vvt
hi i need some help. i have a problem with my roof on a 04 megane cc it start to open and then stops working and then start to beep and then its saying roof mechanism fault does anyone know how to reset the roof or fix it or have some idear what to do ?
Re: roof mechanism fault
how far does it go? Does the boot lift at all? Is the mechanism hitting anything in the boot?
You could check the blind switch in the boot. Or a bit more drastic, try the roof manually
to see if the mechanism is running smoothly?
