HELP!!!!!!!Ipod/Iphone Connection for my Megane CC??????!!!
ckier08
Currently Drives:: Megane CC 1.9Dci
Postby ckier08 » Fri Apr 15, 2011 2:15 pm
Only have my car a few weeks and i now want to hook my ipod/iphone up to the cd player.
My car has a 6 cd changer under the radio and steering wheel controls.
Its the 04 newer megane CC! :-)
Just wondering if i buy that ipod lead (with green end) from ebay can i simply connect it to the back of my cd player...?
Also wondering if i take out my cd player from the car to have a look at the back of it will i need to type in the key code again or can i just have a quick look at the cd player while connected and then put it back into the car....?
Thanks! :cool:
willholdsworth
Currently Drives:: 59 plate Megane cc Dynamique s
Re: HELP!!!!!!!Ipod/Iphone Connection for my Megane CC??????
Postby willholdsworth » Fri Apr 15, 2011 2:31 pm
Yes you will need to put the code into the head unit if you dicsconnect the ISO leads, if you keep them connected (as there is no reason to disconnect) then you will be fine
Im not sure what head unit the 04 meg has, if the wires says it will suit then I guess it will be fine. I have drilled a whole through the small compartment under the head unit and feed the wire through there, keeps it tidy and a nice place to put your ipod.
If its the same as mine it will sit next to a yellow socket at the back of the unit, its so simple to do, you will need to enable AUX on the head unit, it is in the advanced menu setting
Enjoy!!
Image Owner of a 59 Plate Chipped 1.9dci CC + Inferno Orange Megane Sport 225
ckier08
Postby ckier08 » Fri Apr 15, 2011 3:31 pm
Ah I see now, I will take the Cd player out and have a look anyway without disconnecting the ISO leads at the back! :-) im sure its the same as yours!!
i hope so anyway!! :)
That sounds like a great idea I would hate leads hanging out from the dash board!
Thanks :) :cool:
