Hi
Just looking for advise on how to fit new speakers into the rear of a renault megane cc II as it seems to be a pain just to take the old speakers out,
Many thanks
Matt
rear speaker fitting for renault megane cc 2007
- Currently Drives:: Renault Megane CC 57 plate
Re: rear speaker fitting for renault megane cc 2007
Only way to get to them is roof down, rear seats out completly, seat belts disconected, and side panel off, not to bad really, you need to drop the roof as there are two torx bolts that hold the back rest in place, which you can only get at via the roof being down, will holdsworth has some good images for chrome roll bars on here take a look, you can clearly see the bolts in question, you will basically follow the first few steps, base seat out (pops up - held in place vis 3 clips one in center then one either side, as good pull around these clips will lift it) then to the two bolts in question you have to remove the small plastic covers to see them undo these the rear seat will be free, you will also need to undo the rear seat belt to remove completly, once this is out look towards the side panels, they are hled in place by the door base platic base plate, this pops up (on clips as well), you will need to undo the large torx bolt hoding on the front seat belt lower bracket, the is shaped like a U s owill need to once bolt is out push back into the door jamb the pull towards inside of car to remove as it sit in a slot and hole affair simple to get at and get out.
once these are undone you vcan now look at side panel, which is held inplace with those silly plastic clips, where you turn to unlock then pop them up and out with a screw driver carefuly, once they are out (5 I think) you can lift off side panel, undo speaker wire and window switch cable, and take away panel....
Seems quite a lot but it is quite simple really, as said have a look at wills post on Chrome roll bars on here, so very good images, showing you how to get rear seat out. I als owrite a how to for rear window reg removal, that will tell you how to get the side panels off as well, bit more indepth than above, no images though, so see wills!
Hi all
I have a 2007 megane caravan I'm wondering at the radio I have cables for 4 speakers which means 8 wires in back doors there are no wires does anyone has any idea
