"CHECK INJECTION"
BlackpoolPete
Currently Drives:: Renault Megane 2.0 convertible
"CHECK INJECTION"
Postby BlackpoolPete » Thu Feb 24, 2011 5:24 pm
just purchased a 2003 megane 2.0 convertible, and am occasionally getting the message "CHECK INJECTION" along with the SERVICE light. And when this happens,it is very jerky when pulling away in first gear.
willholdsworth
Currently Drives:: 59 plate Megane cc Dynamique s
Re: "CHECK INJECTION"
Postby willholdsworth » Thu Feb 24, 2011 8:14 pm
hmmm Strange. The computer is saying that its the fuel injection system. Take it to a garage that has a diagnostics system that they just plug the car into and get them to (in theory) reset the computer. I had the same with a 206.
OR it could be the coilpack on the way out. Do you have it in any other gears ?
Image Owner of a 59 Plate Chipped 1.9dci CC + Inferno Orange Megane Sport 225
ashtoguy12
Currently Drives:: megane cc
Postby ashtoguy12 » Thu Feb 24, 2011 11:46 pm
read the post in problems on changing glow plugs. It could just be a glow plug needs changing. i had the same garaged change glow plugs and a relay.
willholdsworth
Postby willholdsworth » Fri Feb 25, 2011 8:09 am
ashtoguy12 wrote:read the post in problems on changing glow plugs. It could just be a glow plug needs changing. i had the same garaged change glow plugs and a relay.
Good Point!
ChrisM
Postby ChrisM » Fri Feb 25, 2011 9:24 am
its a 2.0ltr 2003 car! so its a petrol! biggest diesel they made then in the meg range was the 1.9Dci, sounds like a semi blocked injector, try some redex or injector cleaner through it befor you get ripped off by the dealer!
ashtoguy12
Postby ashtoguy12 » Fri Feb 25, 2011 9:34 am
If its a similar fault code maybe it could be the spark plug. Just a Guess though. Might be worth a check
willholdsworth
Postby willholdsworth » Fri Feb 25, 2011 2:50 pm
Funny you should say that I bought some Wynns Injector cleaner today, the 1 use ever 3 months bottle. I think its better than redex, but thats just my opinion of course. They all supposed to do the same thing.
Obviously mine was Diesel version
ashtoguy12
Postby ashtoguy12 » Fri Feb 25, 2011 7:23 pm
Thats interesting I only just used the exact one for my diesel after i had my glow plugs done.
manoman48
Currently Drives:: 1998 Volvo S40 T4
2004 Megane II CC 2.0L
Postby manoman48 » Fri Feb 25, 2011 9:09 pm
In our case the same occassional error was due to faulty coil packs. Changed those and the spark plugs with no recurrance in about 4000 miles so far. Ours is also the 2.0l petrol CC.
willholdsworth
Postby willholdsworth » Fri Feb 25, 2011 11:24 pm
manoman48 wrote:In our case the same occassional error was due to faulty coil packs. Changed those and the spark plugs with no recurrance in about 4000 miles so far. Ours is also the 2.0l petrol CC.
I had the same on my 2.0L 206
BlackpoolPete
Postby BlackpoolPete » Sun Mar 20, 2011 9:58 am
UPDATE ...........Took it back to the guy I bought it from, (still in the 28 day warranty). Drove 60 miles to his garage, and it never came up with the problem. He put it on a computer,cleared the codes and we went for a run in it, and then he plugged it back in,and it showed no faults.
Drove 60 miles home,no problem. Two weeks later I have got the toxic fume light and service light on constantly and yesterday the check ignition light is back on,along with kangaroo performance in 1st and second.
Was wondering,I have RAC recovery,will they come out and fix it ?
willholdsworth
Postby willholdsworth » Thu Mar 24, 2011 1:49 pm
Im not sure RAC will be able to fix that at the road side, but I could be wrong. It could be an ECU problem
ChrisM
Postby ChrisM » Mon Mar 28, 2011 8:39 am
Could well be a faulty coil pack giving a weak spark and not burning the fuel in the cylinder fully, which will I think put on your toxic fume warning light and service light, kangarooing could be coil pack gone completly now or on its very last legs!, hopefully a cheapish fix for you.
