I have just bought and loaded a set of 3 DVDs from a chap called whirlybob7871
Ebay Item number: 320596395405
For a massive £3.28 and Guess what they work a treat, so if you want Dialogys get it there.
The guy is very helpful as well, not that I needed any help with the installation as it loaded fine no trouble at all onto an XP Pro machine.
Dialogys DVDs for sale.
Re: Dialogys DVDs for sale.
Once I managed to get my car codes from the door label and entered them in the
software it was all good!
I can recommend this software too. Very detailed and informative.
Nice one, I was just about to say figured it out.
1st got here to understand your oval plate on your door http://www.bba-reman.com/content.aspx?content=Test_for_Renault_Key_Immobiliser_failures_emergency_recode
you will get all the info off this plate that dialogys will require, this is the same plate any Renault dealer will look at.
My vehicle Type for my 1.9DCi Privalige CC is EN0G
So yep it works a treat once you get all the info in.
Does this version have teh Scenic III PDFs yet or does it use mainly the Megane III ones and a the odd diagram like the 2009 version?
If you give me the model codes and an example of where it might be wrong I can take a look?
It lists all models upto July 2009, with Secnic Mark 2 & 3 listed, it is on Item number: 320596395405
or maybe http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320596395405&ssPageName=ADME:X:AAQ:GB:1123
If the link works, take a look.
The plus side is it actually works, I have had a few of these now and they always bomb out on missing DLL's or even data links, the only other working one I had was completly in Russian, you where told how to change the language in one of the files so it once loaded it opens in English but it just lock you out and complained about a missing file, in other words the english language portion of the file was not there.
so at least this one is a working one and cheap.
