Windows leaks when it rains !! on a CC 2004
- Currently Drives:: 2006 megane 1.5dci 106bhp
My front windows leak when it rains do you know if you can adjust them to push more against the seal or is it a new seal please help
Re: Windows leaks when it rains !! on a CC 2004
I think you can get new seals for them, seen then for sale a few times on ebay, could always try local dealer for a shocking price, of a bit of vasalene sometimes works.
Look under your doors to large rubber grommets, remove them and look up inside if you see a torx screw in each hole you can adjust cant remember which way, mine didnt have them so had to remove door glass and alter via glass clamps.
Alan
Alan
Megane CC 1.6vvt and 1.4 clio
Alan!! Thank's very much for this tip, I had a slightly leaky passenger window and after trawling through this forum it's all fixed!
If anyone else has this problem and isn't technically minded (this took me a while to figure out, doh!) the window has to be fully down for you to be able to see the adjustment screws through the little holes at the bottom of the door. Tighten them clockwise and they slowly go up, anticlockwise brings them back down. The front of my passanger windown had dropped slightly, maybe 1.5mm, but enough to allow a small leak. About 8 quarter turns and she's perfect again
