Broken Spring things to know
Posted: Mon Jul 12, 2010 3:42 pm
Just done this and struggled like a pig.
broke on a sleeping police man at 10mph, an almighty bang then a limping renault! anyway.
mine broke around 10/15cm from the top. car was drivable but slowly.
on removal I found the spring had destroyed the top bearing under the stut mounting. took me ages and a LOT of swearing to remove as spring and sprung past the top mount so was at full extension in the wheel arch and not much room to work with. these are my views on what I should have done.
1st before removing wheel, slacken off hub nut, ready to remove hub
why! well I didn't bother as I figured I will pop off wheel, undo the 3 top mount bolts then undo pinch bolt in hub, thus removing complete suspension leg -WRONG once the 3 bolts on the inner wing where lose spring shot downards to its full extension, now I don't have any room the wiggle out strut leg as the spring force is pushing down on it, which is pushing hub down taking away all my working space.
If I had done the above blue first, then after releasing the top bolts I would have removed caliper, hanger and finally disc, unwound hub nut fully pushed Drive shaft out of back hub would have been free to pop off - job done.
NO I struggled for an hour trying allsorts to force this blinking spring, in the end I clamped it in situ [spring clamps] used my jack to lift the stut up against the cars weight, hit the hub with hammer dowards until I could get enough room to pop of the hub - not really the correct way to do it , but no other option left, hub nut was way to tight to be undone with the hub loose, could not re-attache hub becasue of sprung spring!
ALSO it takes a massive amount of force to compress a CC spring small enough to get the top mounting on, I had to do it in work with a mitsubish Heavy duty compressor, and gritted teeth.
NOW back to the hub, had I removed the hub 1st then the refitting of this strut again would have been simple, as I found I could not get enough work space to engage the lower strut into the hub, again loads of brute force and a hammer and bit "o" wood finally got it engaged again not an ideal way to do it, was not easy but once this was done job was simple.
So simply if you break a spring, REMOVE YOUR HUB - SLACKEN 1ST THE HUB NUT it will make the job easier to do stripping and replacing, but on strip down beware that spring is still slighly compressed not much but enough to give you a fright if unaware, it is a long spring in a little area, personally I don't think your £10 spring compressors from Halfrauds would be man enough to pull it down enough to get the bearing and top mount on.
So there it is, I did it wrong at the start and was not able to put it right once those top mount botls where undone, next time hub is coming off to save on the hammering, bad language and the insational need to kick it hard! Hub nuts are hellish tight, so undo while car has its wheels on on the floor.
