card key
Posted: Thu Feb 18, 2010 11:47 pm
by ziik
hi the card key has 3 buttons my mate has worked out one to open top and bottom to lock but any idea what the third one is .
also when she lock the ights flash so she knows its locked then she deadlocks it but how do u no f it has an alarm , she has locked it and tried opening door not a beep , any idea as to how to check if it has bog renault alarm
Re: card key
Posted: Fri Feb 19, 2010 8:13 am
by direstraits
The third button is for un/locking the boot. If you don't have motion sensors inside the vehicle, there is no alarm. As far as I know.
Re: card key
Posted: Fri Feb 19, 2010 10:20 am
by ChrisM
2004 CC alarmed with bog standard Renault Alarm, to check alram you can either open a window, lock it leave a few seconds then wave hand inside car whilst still locked via open window, or as I did by accident half shut the door, in other words close it so it catches but does not shut, sure you have come across this with these doors, you end up using your bum so make it fully catch!, well close it until it just catches, but not fully shut, lock it [ car will not lock if door is not on the catch], again leave it a few seconds, then bump the door fully shut, this should set it off as I found out at 10 at night, so had to rush back in for card to de activate.
It will also sound with the roof off if you lock it, takes a while on some occasions and not on other, so it must depend on what it picks up on the sensors.
OFF TOPIC!
Does it Auto lock? mine does, never knew it did, but if you lock it, then go and get some thing out of it without putting the keycard in slot, shut the door and walk away, it locks after a few minutes by itself.
