Air Con Fuse how the hell do I get to it ?
capital cat
Currently Drives:: Megane Coup Cab Priv 56 plate
Postby capital cat » Thu Jun 11, 2009 12:30 pm
Hi All
Need to change the fuse for my Air Con pump I believe it's under the bonnet, right hand side, and under the engine management system. Don't really fancy disconnecting the computer but don't know how else to get to the fuse anyone any idea's before I have to pay £50 to change a fuse :cry:
Toodeep
Currently Drives:: 5 Door Privilege 1.6
Re: Air Con Fuse how the hell do I get to it ?
Postby Toodeep » Fri Jun 12, 2009 10:37 am
You'll have to remove the battery and battery tray but the Engine Multiplex Module should just slide out of the fusebox (while still connected) to access any fuses you cannot already get to. With any luck the fuse you want will be one of the handful you can get to without moving the module.
capital cat
Postby capital cat » Fri Jun 12, 2009 4:08 pm
Top man I will give that a go
Thanks Again :cool:
