Page 1 of 2
Mud flaps
Posted: Sat Apr 11, 2009 5:06 pm
by dougieCC
Just a quick one are mud flaps available for the CC, if not would the front mud flaps from a standard megane fit ?
Alan
Re: Mud flaps
Posted: Tue Apr 14, 2009 10:55 am
by wanda
I think because the cc is lower than the standard meggy the mud flaps would be too long.... thats my guess
Re: Mud flaps
Posted: Tue Apr 14, 2009 12:00 pm
by dougieCC
Cheers Wanda, will speak to dealer again.
Alan
Re: Mud flaps
Posted: Thu Apr 16, 2009 4:12 pm
by Ian with Meg
Any luck? I'd like some mudflaps not only to protect from stone chips but the sides of the car get absolutely filthy...well it can rub off on your clothes...
Re: Mud flaps
Posted: Fri Apr 17, 2009 4:11 am
by dougieCC
Waiting for dealer to call back, could not decide...will cahse up today
Alan
Re: Mud flaps
Posted: Wed Aug 31, 2011 7:39 pm
by william john
Just spotted this topic while searching the forum. What was the outcome on the cc mudflaps.
Re: Mud flaps
Posted: Thu Sep 01, 2011 5:54 pm
by wanda
Yea, interested to know.
Re: Mud flaps
Posted: Thu Sep 08, 2011 6:56 pm
by william john
Went to Halfords on Monday and looked at their mudflaps.they had two types in stock, their own brand which looked good being a contoured rubber variety and a pair made by Cannon. Decided on the former as i had fitted the Cannon type before on another car and found that they could get trapped between the rear wheels and the kerb when reversing and would pull off ripping the flap and damaging the fixings not to mention the bodywork. Here is how i fitted the Halfords moulded type to the rear of the car.
1. Remove packaging and discard paper template and the plastic fixings.
2. Align mudflaps to rear wing and decide best height from floor. I placed mine some 85 mm distance from the top edge of the flap to the seam wher the rear side quarter joins the rear wing.
3. Warm up the ruber with hairdryer gently and shape bottom of edge back at 45 degrees.
4. Drill flap wth 3/16th drill bit at two points at back edge that you have just bent over and run 1/8th pilot drill up into bottom of wing an rubber dirt deflector and fix with 2 self tapping screws.
5. Jack up car, safely support car and remove wheel.
6. I then made three more fixings using the same proccess as before through the platic inner mud shield, again with self tapping screws.
7. Refit wheel and repeat on othr side.At this height i think they look good and will not ground.
This is how i did it. Someone may have another way but i am pleased with the result.
P.S. DISCLAIMER. I take no responsability for any accidents caused by others following my advice.If your not sure or confident with power tools, removing wheels, hoising and supporting vehicle in a safe manner then get someone to do it who is.
Re: Mud flaps
Posted: Sat Sep 24, 2011 9:09 pm
by sparky46
Mudflaps are available for the megane cc but they are plastic moulded ones, not rubber. They are made to blend in with the car bodywork. Cost a bit, look good and work and they don't catch on the kerb.
Easily fitted yourself unless you want to pay the dealership to fit them for around £70.
Re: Mud flaps
Posted: Mon Oct 31, 2011 5:29 pm
by lee00069
Hi guys just wanted to let you know my 2005 megane cc came with them as a factory option and to date is still the only one i have ever seen with mud flaps. The front mud flaps are fine but i found the back ones a bit bulky so i removed them.
Re: Mud flaps
Posted: Tue Nov 01, 2011 10:34 am
by wanda
I got some Clio ones. Fitted without issues. :cool:
Re: Mud flaps
Posted: Thu Nov 15, 2012 8:43 am
by freelanderuk
Sorry for dragging an old post up but interested how you got on with the mud flaps, are they the genuine ones that are contoured to the body , I am after some for my 1.9 DCI cc, any photos
Re: Mud flaps
by freelanderuk
Re: Mud flaps
Posted: Sun Nov 25, 2012 8:03 pm
by davestroud
Hi, I fitted a pair of new genuine CC mudflaps to the front of our 06 Megane CC which I bought privately. They are moulded polythene flaps which fit easily to the wing and follow the wing's contour. They stop some mud too.
I tried to buy a set of rear mudflaps to match the fronts from a local Renault dealer using the correct part code, they ordered them and phoned me when they had arrived. I went along to the dealer to be told that the part number I had supplied had now been superseded and was offered a pair of 'one size fits all Renaults' flat rubber muflaps. I declined them and tried again when we were in France in September, it was the same story there.
I have also tried to match the front mudflaps through a selection of on-line parts finding sites, all to no avail. So I have concluded that they just aint available any more (except secondhand).
Best of luck searching.
Dave
Re: Mud flaps
Posted: Sun Nov 25, 2012 8:25 pm
by freelanderuk
I have ordered some of eBay from Poland that are moulded to the body work of the cc, they are due to arrive on Monday, will comment on them when they arrive
