Door handle button intermittant locking?
navaraman
Currently Drives:: megane cc and a astra van sportive SE
Postby navaraman » Mon Apr 06, 2009 6:11 pm
Hi all,
The wife went out in her cc and when she tried to lock the door by pressing the handle button, it didn't work. It locks from the boot and passenger handle. I have tried it again and it worked once.
Is it a known problem?,
Cheers,
Mark
Toodeep
Currently Drives:: 5 Door Privilege 1.6
Re: Door handle button intermittant locking?
Postby Toodeep » Tue Apr 07, 2009 9:22 am
I haven't an answer, sorry, but I'm merely suggesting that you also post your query in Ownership Problems as more members look there so you're more likely to get a response. Especially as any answer is likely to apply equally to all versions.
I hope you don't mind the interference.
busternlouie
Postby busternlouie » Tue Apr 07, 2009 5:00 pm
I used to have the same problem up until a month or so ago. I found some corrosion on one of the pins in the plug for the door handle whilst i had the door stripped down. Cleaned it up and its worked perfectly since.
navaraman
Postby navaraman » Tue Apr 07, 2009 6:52 pm
Thanks guys,
Looks like a job for Easter weekend :(
Mark
Postby wanda » Tue Apr 14, 2009 10:26 am
navaraman wrote:Thanks guys,
Mark
Did you get it to work?
