Any Advice
LCKC
Currently Drives:: Renault Megane Dynamique CC 1.6
Any Advice
Postby LCKC » Wed Sep 18, 2019 1:49 pm
Hi, got my Megan booked into the garage next week to get checked but thought might be an idea see if anyone has come across this. I have an automatic Megane Dynamique CC. It seems to require very high rpm to make the shift up (like over 3000), this is much more than any other automatic i've driven, it sounds like it's struggling to make the change but once it's made the change engine sounds fine, idle rpm is fine, its just when its shifting up. The RPM occasionally also sticks around 2000 when driving even if no pressure on accelerator (this was the main reason for booking it in, the other issue was noticed after this).
Anybody experienced this or any advice?
TIA
djandree
Currently Drives:: megane II cc 05 reg, megane II cc 07 reg megane III cc 11 reg
Re: Any Advice
Postby djandree » Sun Dec 01, 2019 7:06 pm
At first try to read all fault codes using Renault Clip. Then delete it. You might to readapt a gearbox again
