I have just bought it with 82k miles but its not clear from the receipts I have if the belt has ever been changed.
I have looked on eBay and one seller gave a warning to make sure the right one is purchased as there are two possible. Which is the right kit, also going to replace the water pump. I have found the locking pins on eBay. My motor factor is getting prices.
I assume this can be a diy job as I have been quoted £300
cambelt 1.9 DCI 2005
- Currently Drives:: 2005 Megane convertible 1.9 diesel 6 speed
- Currently Drives:: Megane MK2 2004 + Several Motorbikes
Re: cambelt 1.9 DCI 2005
kevlynnbailey wrote:I have just bought it with 82k miles but its not clear from the receipts I have if the belt has ever been changed.
If you know what you're doing with a spanner, you should be ok.
- MilosB
- Currently Drives:: R. Megane 2 1.9dci sport package
not quite a diy as there are no markings on the cams and you have to lock the flywheel inside the engine and time it etc. not simple at all on the 1.9 dci, and the method of symply locking all the cams to the current position is not really a god job
decided to let my local garage do the job. they did an excellent job.
kevlynnbailey wrote:decided to let my local garage do the job. they did an excellent job.
how much did you end up paying?
i would have thought it to cost around £125 - £200.
I know a local garage that does VW/Audi ones for around the lower end of that.
300 in the end. water pump, cambelt and tensioner with labour and vat.
