Window problems
Marathon
Currently Drives:: Megane Cabriolet
Window problems
Postby Marathon » Fri Aug 29, 2014 6:57 pm
I have a 2005 megane cc 1900, the problem is the rear windows. They operate from the centre console switch but do not operate from either the drivers door or rear passenger switches. I have checked the fuses and they seam ok. When I check the power to the door switched I get 12 volts on the rear window switches but no voltage on the child safety switch for the rear windows. Is there another fuse somewhere or is there something else I can check.
Brinneh
Currently Drives:: 1.9 Diesel Renault Megane II Cabriolet - 2006
Re: Window problems
Postby Brinneh » Sat Aug 30, 2014 11:44 pm
I have the same problem but only with the rear driver's side window. I can put it down with the driver's door control, but cannot put it back up. The switch under the window does not put it up or down. I have to use the centre control switch to put it up, which can be annoying when I want to just control that one window. My mechanic has taken a look at the switches and says he cannot find anything wrong with them.
Marathon
Re: Window problems
Postby Marathon » Sun Aug 31, 2014 8:08 pm
I've been told it might be the body control unit that's faulty but can't find out where it's located on the car.
Tony
FEWRIOUS
Currently Drives:: 2005 Megane CC
Re: Window problems
Postby FEWRIOUS » Mon Sep 01, 2014 4:27 pm
This also could be down to the temic module at the bottom of each motor as these are common problems, also check the block connector under the passenger seat, you can see the flap if you move the seat as far back as possible and check to see if any moisture or water as it can cause numerous problems if block connector has damp or water in :cry
