honking when reversing
mitachu
Currently Drives:: 2006 Megan CC Dynamique
Postby mitachu » Mon Jun 30, 2014 6:25 pm
For some reason, after I have been driving for a while and then stop and reverse, my CC makes a honking/foghorn type noise from the rear end. I have no idea what it could be other than a bearing, perhaps??
Meganeccdarren
Currently Drives:: Megane cc
Re: honking when reversing
Postby Meganeccdarren » Mon Jun 30, 2014 8:12 pm
Or is it the reversing sensor?
sparky46
Currently Drives:: Renault Megane CC 2ltr Dynamique Auto
Postby sparky46 » Wed Jul 02, 2014 9:22 pm
Hi.
Mine used to make a droning noise from the rear brakes when I reversed. This happened from new. Took it to Renault but they never solved it. My brothers did the same, never sorted his either. Inherent problem as with the electric window fault. Lived with it and now its cured itself. Never made any strange noises when driving forwards. :D
Meganeccdarren
Postby Meganeccdarren » Thu Jul 03, 2014 6:25 am
I tnink it's the rear calipers sticking :rock
mitachu
Postby mitachu » Mon Jul 21, 2014 6:48 pm
Turned out to be the rear brake discs and pads. Got them both replaced and the problem has gone away.
Postby Stranger » Mon Jul 21, 2014 8:19 pm
Blimey, that's a blast from the past! This was something replaced under warranty when I had my Meg II ........... all together now "memories, like the corners of my mind" :lol:
dieselccconvertible
Currently Drives:: megane mk 11 1.9dci cc convertible
rover 75 connoisseur se diesel tourer
rover 75 connoisseur se diesel saloon
motorhome
suzuki rf600 r
Postby dieselccconvertible » Mon Aug 25, 2014 9:39 am
definitely is the rear discs and pads
try reversing and slamming on the brakes somewhere safe, this could dislodge any crap build up between the discs and pads
remember the rear wheel bearings are in the disc assembly too.... could just need grease on them bearings too ok
hope this helps
mitachu
Postby mitachu » Mon Aug 25, 2014 1:25 pm
Yep, it was all sorted by a mate who replaced the rear discs and pads.
Thanks for the input though!
