Replacing Front Discs on RS250/265/275 Brembo
Posted: Sun Sep 24, 2017 12:19 pm
Keywords: Renault Renaultsport Megane III R.S.250 RS250 R.S.265 RS265 R.S.275 RS275 Brembo bolt front brake caliper 160Nm 175Nm
It is not difficult, just the torque values are not listed in the regular workshop manual. So, I found it out...
Brembo caliper bolts to Perfohub (two long bolts per side): 160 N.m not 175 N.m as found somewhere else.
These bolts can be tricky to undo. I use an H12 (Allen key 12mm) impact socket-bit and electrical 450Nm impact wrench.
The same perfohub is used in all RS250/265/275, so the torque for RS275 is valid and the most up to date.
Small auxiliary bolts keeping the disc on the hub (two small bolts per side, not important) 14 N.m
The source of this information is
https://www.renaultsport.com/IMG/pdf/no ... 2.3-gb.pdf
Title:
MEGANE R.S. 275 TROPHY-R
Bi-material Brake Disc - 8201553174
The date in the document properties is 13/06/14
The discs and pads are described at Brembo web site:
https://www.bremboparts.com/europe/fr/c ... 00108031-1
Catalogue RENAULT MEGANE III Coupe (DZ0/1_) 2.0 R.S.
2.0 R.S. (201 kW) 07/14
Exploded diagrams and part numbers are here :
https://excesstext.com/category/automoti ... /perfohub/
Title:
