Replace rear light cluster 59 plate Megane Coupe
Posted: Thu Jun 14, 2012 8:04 pm
by molineux1
Hi, I recently smashed my rear light cluster. I have the replacement part but can't remove the damaged cluster. I have removed the small external screw and the two internal nuts but the cluster won't budge - any ideas? Thanks
Re: Replace rear light cluster 59 plate Megane Coupe
Posted: Sun Jun 17, 2012 11:08 am
by molineux1
Sorted! The manual is right: unscrew internal bolts then small screw outside on the small black cover DO NOT remove the external black cover separately as it's clipped to the cluster. The whole cluster then pulls smoothly backwards however you may need to pull the top internal bolt too as the cluster sits quite tightly. The connection unclips easily. When replacing the clusterit needs an extra firm push to get it to seat back correctly. It was as easily as that and there's no clips etc that can be broken during replacement. Phew
Cluster cost £41 with bulbs delivered from JH Cars Ltd Lanarkshire
Posted: Sun Jun 17, 2012 7:44 pm
by Stranger
Glad you got sorted and £41 doesn't sound too bad
Posted: Mon Jun 18, 2012 5:54 pm
by molineux1
Great to get it sorted...thought it may cost hundreds!
Posted: Tue Jun 30, 2020 10:27 pm
by q292u
I got my rear light cluster for £15.99, delivered. Nice.
Arrived today. (eBay).
