Dashcam hardwire
The section for all Megane III talk.
Coedffranc
Currently Drives:: 2107 Megane Sports tourer 110dci
Dashcam hardwire
Postby Coedffranc » Mon Aug 06, 2018 3:36 pm
Have a 2017 Megane Sports Tourer 110dci. Have fitted a 'Nextbase312' dashcam and I now need to hardwire it with the connections provided.(ATM mini type). I need to connect it to the a fuse that only becomes alive when the ignition is switched on. Cannot find a detailed diagram, although there is a plan on the rear of the fuse box cover. Because they are the ATM mini type fuses, access is much less than previous ATO/C type. The connection will be piggy-backed and appear to be quite simple, but my hands are like shovels, so i'll probably have some difficulty. Camera works great with the trailing lead, so no problems there. Anyone able to help, or provide info as to which is the best fuse to use. Thanks
Return to “Megane III”
Users browsing this forum: Google [Bot] and 2 guests
