Hi All,
just wondering if anyone has any experience of de-badging. I really like the i-music I have, mainly bought this edition for the alloy wheel style and rear parking sensors. However I don't think the i-music logos do much for the car (on the rear quarter panels). Just wanted to know if anyone has removed and how cleanly they came of. If there's a risk of paint damage I would rather live with the badges. I doubt the badges have a pin locator, probably held on with adhesive foam?. Of course another problem is the paint may have faded as well leaving a imprint behind the badge. Any hints/experience in this area?.
De-Badging
- Stranger
- Site Admin
- Currently Drives:: BMW X1
Re: De-Badging
Last time I de-badged anything I used a hair drier to warm and melt the glue then slid an old credit card carefully between badge and bodywork
Job done after a bit of polishing to remove and residue.
Re: De-Badging
thanks for that, I had heard of the hairdryer technique but the credit card was new to me and sounds a great tip. Also since looking came across advise to remove foam adhesive remains with tar remover. Still not sure whether to attempt as its in such a prominent area of the car. If it went wrong and left any sort of mark I would probably have to buy new badges to recover as I cant see normal double sided sticky foam lasting outdoors.
- Stranger
- Site Admin
Re: De-Badging
You should be ok so long as you follow the tar remover instructions.
I have some Tardis which is nasty stuff if used incorrectly but I've never come a cropper using it correctly.
I would advise, in case your tar remover doesn't mention it, not to use on an area if it's had any non original paint, i.e. A respray or touch up as there's s good chance there'll be no lacquer over and you could remove the paint.
if in doubt test on an inconspicuous area first, under the sill or in a door shut are good places.
Users browsing this forum: No registered users and 16 guests
