Sedan boot problems
Discussions on the Megane II sedan
Keith1962
Currently Drives:: Megane dynamique 1.9 dci 4 door
Sedan boot problems
Postby Keith1962 » Tue May 20, 2014 10:58 am
Iv'e got a 2004 sedan and it has the usual problem with electrics.
The boot won't open, i've re-wired from the lid to inside the car, no joy so i removed the switch and lock.
I'm not an expert with car electrics so all i did was tested the switch for continuity, it gave me a reading when i pressed the switch.
I removed the motor from the lock and tested that, it spins ok.
Is there anything i can try?
I eagerly await your replies, Keith
Keith1962
Re: Sedan boot problems
Postby Keith1962 » Sun Jun 14, 2015 1:54 pm
1 year on and still waiting...........
q292u
Global moderator
Currently Drives:: 2005 Renault Megane 2 1.6 VVT Dynamique
Postby q292u » Tue Oct 18, 2016 7:17 am
Possibilities I can think of:
Electrical problem between switch and lock.
Lock broken/jammed.
Is there current to the switch?
Is the boot lock on a different fuse?
Did you ever get this sorted?
Return to “Megane Sedan”
