hi i have a renault megane 1.6 5 door dynamique automatic reg year 2007 and recently i exprienced a strange fault
My automatic gear lever will not release electrically and has to be released by pressing a small button under the gear change plastic cover also i have lost use of the cruise /limiter control and likewise the manual operation of the gearlever does not does not operate
normally when selecting drive and moving the lever to the left the manual system can be engaged and movement of gears can be done by moving lever foreward or backward also
there are no led indictions on the instrument panel
i have checked all fuses under the glove box on passenger side and found to be ok
apart from these problems the car drives ok
has anyone any suggestions
electrical problem
Re: electrical problem
sounds like a sensor in the box has packed up. you also have a module that sits on top of the gearbox that controls it's operation. check that it's connection in secure and water free. you may have to remove the battery and the tray.
