Coolant loss but no apparent leak
The section for all Megane I talk.
Edc1
Currently Drives:: Renault megane 1999 1.4 16v petrol/LPG
Postby Edc1 » Sat Sep 16, 2017 12:37 pm
Hi
Have Renault megane 1999 1.4 petrol, and from this year noticed loss of coolant. Approx 1ltr for every 600km.
It still works well. Mec did high water pressure test and identified very small leak in one of the coolant pipes which he replaced. But otherwise can't find anything else.
Water pump was replaced 2-3 years ago.
Could it be cylinder head gasket? But don't notice any bubbles in expansion tank.
Any idea please?
Edward
Re: Coolant loss but no apparent leak
Postby Stranger » Fri Sep 22, 2017 11:25 am
Check oil cap or if you don't have an easily accessible oil filler cap check dipstick hole for emulsion (white creamy liquid where the oil has mixed with water) this is one of the signs of a blown head gasket however, this can also occur if the car has been stood for a long time or run only over short distances so don't despair until a few more checks are done.
Return to “Megane I”
