heater blower 98 convertible
- Currently Drives:: megane convertible
Hi gang, got a 1998 megane convertible 1.6e no air con, the heater blower inside the car no longer works, i have changed the resistor, control panel, fuse, checked the blower motor across a battery and it spun up, after all this still no joy!! any help would be great as its freezing in the morning and cant see much. thanks again .
Re: heater blower 98 convertible
Did you check the switch?
thanks for replying, switch?? onlt the one you turn it on with inside the car, that switch is part of the control panel, is there another? thanks mate.
