Needed to take the bumper off and remove the headlights, now I have replaced everything and the headlight levels on the lights are so low its like driving in the dark at night as they are pointing really down, how do I raise them up ?? prob really stupid question but many thanks in advance for your help
MJ
Headlight Levels
- Currently Drives:: Renault Megane 1.9 DCi
Headlight Levels
Renault Megane II - 1.9 dCI
Re: Headlight Levels
easiest way is to take in it into a garage and ask them, there's no-way-on earth that it would cost much to do it
- nickbell69
andywills wrote:easiest way is to take in it into a garage and ask them, there's no-way-on earth that it would cost much to do it
Unless you go to a renault dealer
nickbell69 wrote:Unless you go to a renault dealer
- WebCode
Why did you have to remove the lights??
Have you reconnected the motorised headlight units.
Have you replaced the light units, if so have you refitted the level motors correctly..
Do they go up and down when you move the level control switch.
etc etc etc
etc etc etc
yeh they go up and down but when at the '0' setting it is way too low - taking it to a garage will be ok but bet its a bumper off job again ??
- WebCode
So let me ask again, why did you take them off?? as it may be significant to my answer to the problem..
Needed to get to the rear of the lights for the wiring so nothing to do with the headlights - basically needed to cut into the main beam wire - so needed to remove the headlights - think its something stupid like i have done the bolts up too tights which pulled the headlight down fractionally which then puts the beam out
- Bumpy macaroon
Bumpy and full of coconuts.
