oil capacity of megane 1.9 dci
Marky67
Currently Drives:: megane cc monaco
honda civic type r gt
Postby Marky67 » Wed Dec 03, 2008 11:12 pm
hi there, is there any kind person on here that can tell me the engine oil capacity of the 1.9 dci fap engine please. did a google search but no joy. thanks in advance!
nickbell69
Currently Drives:: megane 1.9dci priv 53
Re: oil capacity of megane 1.9 dci
Postby nickbell69 » Thu Dec 04, 2008 12:12 am
Changed mine recently and it took about 5litres i think.
pw981
Postby pw981 » Thu Dec 04, 2008 2:53 am
there used to be a post in the FAQ section I think, don't know where its gone though! It's either 4.7 or 4.8 litres, I've forgotten!
2004 Megane II 1.9dCi
IainMW
Postby IainMW » Thu Dec 04, 2008 7:29 pm
pw981 wrote:there used to be a post in the FAQ section I think, don't know where its gone though! It's either 4.7 or 4.8 litres, I've forgotten!
4.8 inc filter if memory serves me well?
If it's the FAP fitted model then you MUST USE a 0W30 or 5W30 ACEA C3 oil, anything else can potentially knacker up the FAP filter
Marky67
Postby Marky67 » Thu Dec 04, 2008 8:52 pm
cheers guys, i did know that it was 5w 30 acea c3 oil, and knackering the soot filter might not be a bad idea if was not so expensive to replace, i am currently driving 150 extra miles each fill up to regenerate it. i am thinking of emailing renault to ask them if any thing can be done, as i know there not the only car maker with this problem :banghead
WebCode
Postby WebCode » Thu Dec 04, 2008 9:36 pm
IainMW wrote:4.8 inc filter if memory serves me well?
4.7 litres inc filter..
IainMW wrote:If it's the FAP fitted model then you MUST USE a 0W30 or 5W30 ACEA C3 oil, anything else can potentially knacker up the FAP filter
There are some 5w40 C3 spec oils available now that are fine to use with FAP.. for example Castrol Magnatec Professional or Edge..
data sheet here.. http://datasheets.bp.com/bpglis/lsdsukf.nsf/0/E043ED739ED06D7D802573C600388493/$file/090574.pdf
And sold by Opie oils.. http://www.opieoils.co.uk/p-719-castrol-edge-td-5w-40-advanced-synthetic-engine-oil.aspx
In our dealership we use Profesional C3 grade in all our vehicles now...
IainMW
Postby IainMW » Fri Dec 05, 2008 8:47 am
Obviously it did not serve me that well! :sad
Funnily enough I had the Laguna serviced a couple of weeks ago and they used Magnatec Professional 5W40 C3
Users browsing this forum: Google [Bot] and 51 guests
