Just wondering if anyone has any problems demisting there megane, Or is it just a falut with mine (or me)
i have to have heat on full and blowers on full just to see out the window a little. Getting very Pi$%ed of with it.
Anyone else have th esame problem or can anyone shed a little light on this problem before i end up crashing ...
demisting my megane
- Currently Drives:: 2006 megane 1.6 16v dynamique
Re: demisting my megane
I find putting on the air-con on full blast at the screen works quite well. Yes it cold but it works.
- Currently Drives:: Megane 1.5dci 53 Plate
You have got the dial to get air from outside and not just to recirculate the air inside the car?
You may find this will cure your problem as mine used to get misted up all the time
- pw981
- Rally Driver
You may have a water leak somewhere inside the cabin, check all the common areas which leak in the Megane!
2004 Megane II 1.9dCi
- Bumpy macaroon
As mentioned, stick the recirculation knob to the 12 o clock position has picture of carwith arrow going into drag air in from the outside, the 6 o clock position has the car with the arrow inside which is great if there is a nasty smell outside coming in.
But for normal driving leave in the 12 position otherwise you are sat in stale air which will go moist from you breathing or if you get in damp from rain etc , it does make quite difference, and if really having problems stick the air con on leaving the heat setting on high, other then that check for water leaks.
Bumpy and full of coconuts.
- 72uoba
- Currently Drives:: Renault Laguna 2007 GT 175
Toosh wrote:I find putting on the air-con on full blast at the screen works quite well. Yes it cold but it works.
The air-con can be used at any temperature you like
It is very effective at de-misting and it is the norm rather than a last resort to use it to clear the windows - cars with climate control will automatically switch it on whenever they are set to clears screens
- mcmurr4y
- Currently Drives:: FN2 Type-R
Check the pollen filter. might need changing and could be stopping clean air getting to the fans.
I have found that actually the opposite works well, i put it on recirculate with aircon on as this warms up faster whilst extracting the moisture it also seems to blow harder on recirculate. This used to work well in my clio as well.
56 Plate Twilight Blue 3dr 1.9 DCI 130 with panoramic roof, handsfree card, auto wipers and lights, 6 CD in dash changer
Users browsing this forum: No registered users and 84 guests
